Need rear window info
Old May 31, 2006 | 10:58 AM
sephirothq's Avatar
sephirothq
Default Need rear window info
See post.
https://dodgeforum.com/m_477618/mpag.../tm.htm#477618
i am trying to find out what years and what cab types will fit my truck.
Would a rear window from a 1998 extended cab fit my 1995 reg cab?
thanks
Old May 31, 2006 | 03:04 PM
crazy1snow's Avatar
crazy1snow
Default RE: Need rear window info
i imagine the windows from the same year are the same and i know my '96 had a sliding window on a reg cab. best i can say is get a measuring tape and measure away. another idea is to call a glass shop they should know or be able to find dimensions for ya.
Old May 31, 2006 | 06:12 PM
sephirothq's Avatar
sephirothq
a glass shop might just try to sell me a window without providing information about what will fit.
i am looking for someone that might work at a glass shop on the forum and know.
Old May 31, 2006 | 06:23 PM
Sehr916's Avatar
Sehr916
I had to get my rear window replaced and they put in one of those cr lawrence sliders to replace my oem slider. Not bad except its pretty damn noisy
Old May 31, 2006 | 06:27 PM
Sinister's Avatar
Sinister
a glass shop should help you where you need it if they want your business,. if you go and ask for window dimentions, they should still give them to you.. if they dont, I wouldnt use them.
Old May 31, 2006 | 10:51 PM
Chopper1's Avatar
Chopper1
Go here and search for your model. It will break it down by years. If nothing else cross check the part numbers....
https://www.1stchryslerparts.com/oe_parts_catalog.html
