Coil-Spring Spacers
Old Jun 3, 2006 | 01:54 AM
Sehr916's Avatar
Sehr916
Default Coil-Spring Spacers
Hi. Im thinking of getting a coil spring spacer kit for my Ram. Its a 2wd and I was wondering what amount of lift will level the truck out nicely and even possibly what size tires I will be able to fit in the front. I heard that 1 1/2 inches will level the front with the back. I was also hoping for some input on people who have done this. I am thinking of going with Daystar suspension or Rough Country. How were the insttructrions with these kits and how hard was the install? Thanks a lot
Old Jun 4, 2006 | 12:19 AM
DODGERAM808's Avatar
DODGERAM808
Default RE: Coil-Spring Spacers
the 2" leveling kit will level the front with the back. most shops will say you can only fit 31x10.50's but with a linttle cutting of some un-needed plastic you can get 33's under there. with a leveling kit and a 3" body lift you can fit 35's no problem
Old Jun 4, 2006 | 01:42 AM
Sehr916's Avatar
Sehr916
Okay thanks. With the 2 inch spacers should I go with Rough Country or Daystar? Im also not sure If I will need to get the front end aligned after doing this. Thanks a lot!
Old Jun 4, 2006 | 05:26 AM
20dodgeram01's Avatar
20dodgeram01
you should always get your tires re-aligned after a lift.. but i have a 3 inch lift on mine and havent gotten around to it yet.. and its been about 3 months now and i still havent noticed any uneven tread wear... rough country or daystar.. both are good and cheap in price.. i went with a 3 inch rough country lift for mine but most go with daystar for leveling.. also.. im assuming you have 245's on your truck right now?? with a 2 inch lift i'd say no bigger then a 285.. (32 1/2 inches or so)
Old Jun 4, 2006 | 04:57 PM
Sehr916's Avatar
Sehr916
I'll go with Daystar then. Yes I do have 245's and I was hoping to get some 285's. Don't want any bigger. Thanks for all the help. How much is an alignment?
Old Jun 4, 2006 | 06:25 PM
20dodgeram01
its like 70 bucks here.. so probally 50-80 bucks depending where you are
Old Jun 4, 2006 | 06:26 PM
Sehr916's Avatar
Sehr916
Okay thanks. My last question is if my shocks will be fine. I just put new Bilstein's on and don't want to shell out anymore money since Im going to be getting tires soon
Old Jun 4, 2006 | 08:53 PM
DODGERAM808
the shocks will be fine. daystar recomends that you change the upper balljoints due to the fact they will be a little stressed, but i havent heard of anybody having problems with that.
Old Jun 4, 2006 | 09:22 PM
Sehr916's Avatar
Sehr916
Okay. Im going with Rough Country because the only place I can find the 2inch of Daystar is on summit for double Rough Country. I'll have to stick with the stock ball-joints for now because I gotta lay down some cash for a floor jack as well. Thanks for all your help
