Tire inflation pressure
Old Jun 5, 2006 | 01:02 AM
mattyge's Avatar
mattyge
Default Tire inflation pressure
Hey everybody i could really use your help here. Ok on the door of my truck it has the recommended tire size and pressure P225/75R16 41psi cold. Ok what is on the truck are Bridgstone Duravis LT245/75R16 max 80psi. Obvousily they don't match but what tire pressure should i be running them at. I want to get the best mileage with the smoothest ride. I had them at 41 before but i bumped them up to 45 to see if the mileage is and better. I'm empty right now so i don't know about the mileage but the ride seemes to be harsher. Any suggestions or ideas and can i put 45 in the rear and 41 up front. Thanks
Old Jun 5, 2006 | 01:09 AM
The Burning Rom's Avatar
The Burning Rom
Default RE: Tire inflation pressure
40-45 is usually good. I run mine at 45, but I run them up to 60psi if I'm going to tow/haul.
Old Jun 5, 2006 | 01:53 AM
fiveliterbtr's Avatar
fiveliterbtr
I wouldn't run them less than 50 myself...those are load range "E" tires, and with it being 10-ply (much heavier), too low of pressure will create extra heat and possibly shorten the life of the tire...most lr "E" tires on various makes/models recommend 65/80 or 55/80 psi.
Old Jun 5, 2006 | 02:01 AM
mattyge's Avatar
mattyge
so they're under inflated? will that give me better ride and mpg? 65 or 55psi?
Old Jun 5, 2006 | 02:11 AM
fiveliterbtr
ORIGINAL: mattyge
Higher psi = better gas mileage but at the expense of comfort/ride. Just a minimum of 50psi is all I'm recommending here...it's the tires talking to me
Old Jun 5, 2006 | 02:23 AM
Sehr916's Avatar
Sehr916
For some reason on mine I have passenger tires and the max psi is 35. I usually keep them around 35-40. If you wondered im having rubbing issues
Old Jun 5, 2006 | 02:29 AM
mattyge's Avatar
mattyge
ok i'll try them at 50 see how that goes i never knew they were such heavy duty tires wonder why the ones in the door only say 41
Old Jun 5, 2006 | 02:41 AM
fiveliterbtr
ORIGINAL: Sehr916
The reason is, they're the correct tires for your truck...1500's only come with standard or extra load tires IIRC, 35 or 41 psi max respectively. Someone has previously installed a different load range tire on mattyge's truck.
ORIGINAL: mattyge
Because all DC vehicle tire info stickers have list the minimum acceptable tire size/psi that can be used...like my 2500 for example...door says LT245/75/16...that's what it has on now, just got it used a bit ago...but my build sheet from DC says it came with LT265/75/16...confirmed this by looking at the 265 O.E. Michelin spare that I can't use now.
Old Jun 5, 2006 | 02:43 AM
mattyge's Avatar
mattyge
ok thanks for the info, yeah the tire where just put on before i bought it, they are load range E what does that mean?
Old Jun 5, 2006 | 03:00 AM
The Burning Rom
ORIGINAL: mattyge
It means they're a heavy duty (10 ply) tire....for 3/4 ton and 1 ton trucks. They're thicker and harder than normal passenger car tires or light truck tires. They're made for hauling/towing.
I have E range tires on my truck, and I have no problems or tread life issues running them below 50psi. In fact, even with the burn-outs I still can't seem to wear my rear tires down [:'(] The ride is also MUCH nicer. I've had several people comment on how my truck (3/4 ton with the stiffest spring package) rides better than a typical 3/4 ton and even most 1/2 tons.
