damage to clear coat
Old Jun 13, 2006 | 02:22 AM
jrmcx's Avatar
jrmcx
Default damage to clear coat
What can I use to get "swirl marks" out of clear coat on the hood? Is there an easy product/method or am I looking at a refinish?
Old Jun 13, 2006 | 10:37 AM
hippie49445's Avatar
hippie49445
Default RE: damage to clear coat
If the clear coat is still thick enough, you can wet sand it. Then buff it out.
Old Jun 13, 2006 | 05:09 PM
theshocker's Avatar
theshocker
I use a fine cut polish with a high speed buffer. It will get mild swirl marks out. You could try a fine cut rubbing compound first then do the polish and that might help. I know useing those two got alot of my small scratches and imperfections out of my paint. I also have a high speed buffer, it helps make the difference.
Old Jun 14, 2006 | 11:56 PM
HemiMan02's Avatar
HemiMan02
i work in a body shop and they use a swirl free polish...ibelieve 3m makes it.
Old Jun 17, 2006 | 03:41 AM
ramsportguy's Avatar
ramsportguy
Use mothers carnuba cleaner wax, then go over it with meguairs tech wax.I got a black truck and it looked great after doing this...
thanks
pat
