Frame Bolts replaced for Running Boards
Old Jun 13, 2006 | 12:34 PM
mikebrown123's Avatar
mikebrown123
Default Frame Bolts replaced for Running Boards
Several years ago, I added the Tube Running Boards to my truck to help my preganant wife get in and out of the truck. They came with longer bolts and mounted into the frame without drilling. Now, they are rusty and I ant to get them off, but I cannot find the original bolts. Does anyone know what the bolts were that come from the factory that I replaced????
Argh...
Old Jun 13, 2006 | 01:03 PM
Chopper1's Avatar
Chopper1
Default RE: Frame Bolts replaced for Running Boards
You could probably use the same bolts. If the bracket was very thick, or take up the slack with a fat washer. The dealer recomended 60 ft/lbs for the body bushings. That might need to get verified by another dealer to see if he was close.
Old Jun 13, 2006 | 01:07 PM
mikebrown123
They actually go through the whole width of the tube (3 or 4 inches)...that would be alot of washers...I looked at the manua in the merry x-mas thread, but didn't know how to word it.
Old Jun 13, 2006 | 06:24 PM
Chopper1's Avatar
Chopper1
Depending on what state you are in, either one of us that has a body lift could give you our old ones, or just mail them to you. Or just call or go by the dealer and get them I would assume.
If you like the bars, just get another set.....Mine have gotten rusty. Time for a new set. The black ones for mine, luckily are not that expensive.
