Rear Window Graphics
Old Jun 13, 2006 | 10:43 PM
dodge_dylan's Avatar
dodge_dylan
Default Rear Window Graphics
i was wondering if anyone knew if you could put one of those "rear window graphics" on a rear sliding window instead of a solid window?
Old Jun 14, 2006 | 12:02 AM
The Burning Rom's Avatar
The Burning Rom
Default RE: Rear Window Graphics
It's possible...you'd probably have to cut the decal if you wanted to retain the use of your sliding window. Cutting it would also let you mount it flush with the glass, and keep things from getting under it and causing peeling.
Old Jun 14, 2006 | 02:40 AM
dodge_dylan
hey thanks that was what i was thinking but i wasn't for sure.........so yeah
Old Jun 14, 2006 | 01:07 PM
shott8283's Avatar
shott8283
yes, ive seen people use a standard solid window graphic and just cut to fit, and they also make graphics for sliders as well.
Old Jun 14, 2006 | 08:10 PM
dodge_dylan
do yall have any clue where i could the ones that fit sliding glass rear window? i have only seen the solid graphics
Old Jun 15, 2006 | 12:56 AM
014x459's Avatar
014x459
You use the same graphic as for a solid window. Then you cut it so that is fits each of the three sections.
I saw a Dakota with a sliding window on it today with a wavey US Flag on it. It looks like you have get creative and carefully line everything up, but it should look good if your careful.
Old Jun 15, 2006 | 03:23 AM
dodge_dylan
OK THANK YALL
