Blinkers turn on but dont blink, why?
Old Jun 27, 2006 | 12:10 AM
metlhed01's Avatar
metlhed01
Default Blinkers turn on but dont blink, why?
hit the switch left or right, and it turns the corresponding bulbs on. it turns them on, but they dont blink. even the arrows on the dash stay lit. i cant figure it out, and i HATE most things electrical, so i need some help. thanks.
Old Jun 27, 2006 | 12:12 AM
dodgerules86's Avatar
dodgerules86
Default RE: Blinkers turn on but dont blink, why?
I believe this is usually caused by a bad flasher, which is a circle shape, usually located on the fuse block. They are a few bucks at the auto store, and pop right in and out.
Old Jun 27, 2006 | 12:19 AM
The Burning Rom's Avatar
The Burning Rom
Agreed ^^^
They're located in the little panel on the side of the dash that's accessible when you open the driver side door.
There's one for the turn signals and one for the emergency flashers.
Try your emergency flashers. Do they work?
Old Jun 27, 2006 | 01:48 PM
Chopper1's Avatar
Chopper1
If those don't fix the problem, check the bulbs. In older cars a bad bulb or loose ground/contact would cause the same effect. Have you replaced any bulbs lately?
Old Jun 27, 2006 | 08:02 PM
metlhed01's Avatar
metlhed01
hazards dont work either..
the only bulbs i replaced were the headlights with silverstars.
thanks for the help.
Old Jun 27, 2006 | 09:41 PM
crazy1snow's Avatar
crazy1snow
you have a shorted or bad flasher.
99% confident. unless you messed with wires and did a hack job replacing headlight bulbs won't do a thing.
Old Aug 18, 2007 | 12:35 AM
Mack Bolan's Avatar
Mack Bolan
Junior Member
I have to agree with Chopper on this one. I'd bet it is a bulb thats bad. Try having someone turn onturn signalswhile you walk around truck and verify that corresponding bulb is lit. just my guess...
Old Aug 18, 2007 | 12:42 AM
finny's Avatar
finny
were you towin a trailer. cuz my trailer does the same thing to my truck.
Old Aug 18, 2007 | 01:14 AM
morrgriff's Avatar
morrgriff
ORIGINAL: finny
If this happens, check your ground wire to the trailer. If the trailer is not grounded w/ the truck= lights no blinky blinky![sm=insomnia.gif]
Don't rely on the contact to the ball and receiver. Not a good ground.
Also make sure you have a "heavy duty" flasher in there. Another culprit.
Just an FYI and hope to help!
Old Aug 18, 2007 | 10:48 AM
Socha_62's Avatar
Socha_62
I say check the bulbs...
