engine Temp
Old Jun 30, 2006 | 09:00 AM
Mike Roma's Avatar
Mike Roma
Default RE: engine Temp
Mine runs a just a tad over 200 if the factory guage is accurate. I wondered if that was normal, and considered asking this same question here. Sounds like it's ok. I may put a 180 t-stat in.
Old Jul 1, 2006 | 07:46 AM
azffighter's Avatar
azffighter
So if I put a lower temperature thermostat on would my truck run more better or efficiently?
Old Jul 2, 2006 | 09:09 PM
Big Black Ram's Avatar
Big Black Ram
Yes and no. Using a lower temp thermostat will make the engine more efficent by way of running at a cooler temperature and it will also cause a fair power increase for short money,but you may notice a small loss of fuel milage. I would probably go with the 180 degree as apposed to the 160 as not to mess with the air/fuel mixture too much.
