Overheating when towing
Old Jul 3, 2006 | 11:17 PM
Eagle=ad='s Avatar
Eagle=ad=
Default Overheating when towing
I'm towing a 20ft cargo trailer and my van is overheating. I'm also noticing some ping and knock when going uphill. I've been towing the same trailer for 5 years and it's the first time the van overheats. I've replaced the fan clutch but that didn't make any difference. The rad is only a couple of years old and the tranny is only 8 months old. Anyone have a clue what's up?
Old Jul 3, 2006 | 11:44 PM
Sinister's Avatar
Sinister
Default RE: Overheating when towing
thermostat?
Old Jul 4, 2006 | 12:08 AM
tcarothers's Avatar
tcarothers
If your overheating and pinging when you are towing, i think that your timming has slipped, sounds like you are advanced to much.
Troy
Old Jul 4, 2006 | 12:48 AM
The Burning Rom's Avatar
The Burning Rom
I agree with both ^^^^ and I'd check both. [8D]
Excessive heat (possibly due to a stuck/faulty thermostat) can cause pinging.
The timing being off can also cause pinging and overheating during towing.
Old Jul 4, 2006 | 01:42 AM
Eagle=ad='s Avatar
Eagle=ad=
Thanks for the input. I'll slap a new termostat in tomorow and checkout the timing.
Old Jul 4, 2006 | 03:05 PM
Eagle=ad='s Avatar
Eagle=ad=
Looks like the rad is plugged, getting a flush and a new rad in a few days.
Old Jul 4, 2006 | 05:05 PM
Sinister's Avatar
Sinister
good to hear its just that.. its better than a major problem.
Old Jul 4, 2006 | 06:03 PM
Eagle=ad='s Avatar
Eagle=ad=
Doh! 5 hours of labor and a new rad $799.00 after taxes that's a major problem[]. It's a van and a tight fit in there so the whole front grill and a bunch of other stuff has to come out. Oh well, I guess these days anything under $1000.00 is good news Labor cost is a killer these days.
Old Jul 4, 2006 | 11:28 PM
gamagoat6x6's Avatar
gamagoat6x6
Try a new thermostat. It may not be opening enough for full flow under heavy loads like that.
Old Jul 4, 2006 | 11:53 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: Eagle=ad=
That's why you should consider doing the job yourself. You learn about the vehicle and save money. If time is indeed money, then I believe that my time is definitely worth what a dealer would charge me.
ORIGINAL: gamagoat6x6
Sorry, but that's highly doubtful. Sounds more like he stated, in that there was a blockage.
