Wipers...again
Old Feb 11, 2012 | 07:01 PM
apchevy(lol)'s Avatar
apchevy(lol)
I have a 98 dakota and my intermittent wipers were not working.I put the fuse back in it for power windows(which I don`t have) and wipers were fixed.Great post, just did a search and then became a member.I may have pulled the fuse so I didn`t have to listen to the door chime when I worked on it before.Hell gettin old.SO,IF YOUR TRUCK DON`T CHIME WITH THE KEY INSERTED PUT THE FUSE IN YOU THINK YOU DON`T NEED TO FIX THE INTERMITTENT WIPERS.Ty
Old May 2, 2012 | 08:51 PM
Boosh_1@telus.net's Avatar
Boosh_1@telus.net
Need some help here and hopefully someone has the answer. I have a 2002 Dodge Ram 2500 Diesel 2 wheel drive. Wipers are pretty much non existence here. I have replaced the wiper motor twice, wiper switch on my column as my intermittent stopped working about 3 years ago. Then I was told I probably had a bad ground. Sprayed all connections with a electrical cleaner and also put in a ground myself from the motor to the cowling. Still does not work....................any thoughts?
Old May 3, 2012 | 01:00 AM
dhvaughan's Avatar
dhvaughan
welcome to DF. check for voltage at the wiper motor.
low speed, high speed, park circuit, and ground.
Old Nov 28, 2012 | 01:56 PM
Hawque's Avatar
Hawque
Default Same Problem
Originally Posted by JJF
Does anybody else have this problem, or is it just me?
Yup! Same thing on my '05 1500. PITA!!!
Old Jul 1, 2017 | 05:30 PM
pure adrenaline's Avatar
pure adrenaline
dhvaughan
I nominate dhvaughan to the wiper god position. Thanks bro you saved me so many headaches. Many months ago I noticed my wiper speed was un-adjustable which must have been the same time my keys stopped making a noise when I put them in or forgot to take them out. I have been worried about my wipers but didn't think I needed to fix them until I drove thru Atlanta in the rain two weeks ago. Two weeks after that I sit here praising your wiper mastery and feeling sorrow for what it cost you.
Thank you again for coming on here and telling everyone because you certainly saved me a few headaches, time and money.
Old Sep 21, 2017 | 06:58 AM
ZipperStar's Avatar
ZipperStar
I have a no wiper park situation on my 1999 Durango, however I don't seem to have a blue wire for park supply. I'll just hit and miss with a hot probe and replace a fuse or two till I find the wire to park control. You explained the needed supply well so I'll figure it out hopefully. My intermittent works fine, just a no park issue. They shut off wherever there turned off at. I can dance them into place,, but how irritating. Thanks for info..
