Another Plenum Question
Old Jul 13, 2006 | 09:47 PM
tekstyle's Avatar
tekstyle
Default Another Plenum Question
My truck does not seem to ever burn any oil but it has started to ping pretty frequently.
It seemed to start after I dumped a can of Seafoam down the intake????
It pings under load quite a bit now.
I can see a film of oil in the intake area but my mirror got broken so I can not see in the corners.
I did remove the air breather line from the CAI and there is a good bit of vaccum present coming from the valve cover.
I suppose my question is this?
Do you have to disconect the PCV valve to verify the problem or is any vaccum a sure sign?
Thanks
David
Old Jul 13, 2006 | 10:08 PM
tekstyle's Avatar
tekstyle
Default RE: Another Plenum Question
Using my cheap gauge I have about 2" of vaccum with the PCV line capped off and about 5" of vaccum with the line hooked up.
In either case it must build for a few seconds to show on the gauge.
