front end noises
Old Jul 15, 2006 | 04:17 PM
crazykidjj87's Avatar
crazykidjj87
Default front end noises
well i had a clunk in my front end...so i started replacing parts...i replaces the tie rods, ball joints, wheel bearings, track bar, steering stabilizer, and the sway bar end links...all brand new...and i still have a clunk when i drive down the road over bumps and such.....any ideas? the truck is 95 1500 5.9L auto 4X4
Old Jul 15, 2006 | 04:56 PM
sawdust2's Avatar
sawdust2
Default RE: front end noises
I just rebuilt my front end and there were 3 areas that gave me the annoying clunk. the shock mounts, the swaybar endlinks, and believe it or not the shift linkage. I still get a clunk once in while but I think it's the endlinks. It's a 2wd so I'm sure it's way different. My problem is the 3 inch coil lift changes the angle of the sway bar links and the bushings don't want to stay centered, I think.
I was amazed at how the shift linkage clunk sounded like it was coming from the front suspension, might be worth looking at. And the shock mounts. Just my 2 cents, I'm sure some better qualified 4x4 guys will chime in.
Old Jul 15, 2006 | 05:11 PM
The Burning Rom's Avatar
The Burning Rom
More things to check out...
http://dodgeram.info/tsb/1995/02-05-95.htm
http://dodgeram.info/tsb/1995/19-02-95b.htm
http://dodgeram.info/tsb/1997/19-08-97.htm
Old Jul 15, 2006 | 06:28 PM
CopperDesigno's Avatar
CopperDesigno
I had the same thing and it ended up being the front drive shaft, the slip joint is loose and clunks over small bumps.
Old Jul 17, 2006 | 03:56 AM
crazykidjj87
humm...im gunna have to look into all these things because the noise is REALLY annoying and im sick of it...i just want a nice quiet ride down the road with no clunks or other noises....thanks for the input tho guys i appreciate it
