whats leaking?
Old Jul 19, 2006 | 03:55 PM
newdodge's Avatar
newdodge
Default whats leaking?
ok i was driving this morning and something started clicking unger my hood at a red light. As i pressed the gas pedal the clicking got faster. Then this after noon it started squeeking i think its my belt but something is leaking from it too.
Old Jul 19, 2006 | 05:18 PM
ARbowhunter7's Avatar
ARbowhunter7
Default RE: whats leaking?
What color is the fluid it's leaking? From what you've said, it could be the water pump leaking coolant onto your belt. That'd cause some squeaking.
Old Jul 19, 2006 | 10:48 PM
newdodge's Avatar
newdodge
its green i think its coolant
Old Jul 20, 2006 | 03:07 AM
Socha_62's Avatar
Socha_62
Water pumps probably gonna go. Your gonna want to get that fixed ASAP unless you want to be stranded [&:] Look on your water pump, there are small bleeder holes. If they're wet or leaking that means your pump is on the way out.
Old Jul 20, 2006 | 04:58 AM
The Burning Rom's Avatar
The Burning Rom
I agree ^^^^
Also known as a "weep" hole. If the water pump is crying (leaking) from it, it's time to replace it
Old Jul 20, 2006 | 02:44 PM
mavrik's Avatar
mavrik
a water pump on these trucks is a fun little job...doh....while doing the pump there is a pipe coming out of the drive side (it is a heater hose), replace that too....it is cheap and you don't have to worry about rust and stuff stopping a good seal...
