brake light problem
Old Jul 21, 2006 | 02:06 PM
mill's Avatar
mill
Default brake light problem
i keep on blowing fuses for my brake lights.
why is thes happening?
ill change the fuse and with in 5 minutes it will blow again. pease help
Old Jul 21, 2006 | 02:27 PM
sakdaddyg's Avatar
sakdaddyg
Default RE: brake light problem
check the wiring behind your brake light cover and see if you can find any wires in bad shape i.e. knicked insulation bad connection...also have you replaced the bulb recenlty if so did you make sure you got the proper bulb to replace it with. Other than that could be a grounding issue. Also what size fuse does your fuse schematic call for...are you putting the properly rated fuse in?
Old Jul 21, 2006 | 03:02 PM
mill's Avatar
mill
it calls for a 15 so when it blew i put another 15 in and it blew so then i put a 20 in and it blew that so i took the brake light out and there was a **** load of sand and dirt so i cleaned it out and was still blowing fuses
Old Jul 21, 2006 | 07:34 PM
sakdaddyg's Avatar
sakdaddyg
if it is not a ground fault problem such as a wire that is touching your chassis and blowing the fuse it could be any number of things. Is it the ABS fuse or just the fuse for the brake lights themselves. Is it tied in with anything else like interior lights or anything like that?
It could be that you have a knicked wire somewhere under your truck doing this, or you could be getting a power surge from somewhere else
have you had any work done to it lately that would have required removing your brake light or running of some wires...anything like that.
Old Jul 23, 2006 | 04:30 PM
mill's Avatar
mill
when the fuse blows the abs light comes on but my brakes still work normally. i recently put new subs in my truck and there not working properly either
Old Jul 23, 2006 | 05:27 PM
Sinister's Avatar
Sinister
subs aren't working either?.. no sound or what?
Old Jul 23, 2006 | 07:57 PM
mill's Avatar
mill
well no the work but the amp isnt amplifying, the subs are just as loud as the stock speakers
