air conditioning cutting out?
Old Jul 22, 2006 | 01:49 PM
firechic72877's Avatar
firechic72877
Default air conditioning cutting out?
I own a 1998 dodge ram 1500 pick up with appx.97,000 miles on it. I have been noticing that when I have my air conditioning on, that it will cut out completly when I have to accelerate. Does anyone know what this could be or has anyone had this happen to them?? Please help!
Old Jul 22, 2006 | 03:48 PM
shott8283's Avatar
shott8283
Default RE: air conditioning cutting out?
ive noticed the same thing... every now and then..not constant
Old Jul 22, 2006 | 03:51 PM
TPSDODGE's Avatar
TPSDODGE
its really common what you need is a vacuum check valve on the line that goes to your blend door accuator. its the littel line that goes through the firewall infront of the passenger. I had the same problem till i put the check valve in. I will try to find a mopar number and get back to ya with it. But any cheap check valve from autozone or oreillys will work.
Old Jul 22, 2006 | 05:50 PM
The Burning Rom's Avatar
The Burning Rom
It is NORMAL for your AC to shut off when you accelerate! Almost EVERY car/truck does this.
It is NOT normal for your AC to swtich vents when you accelerate. If the air goes from the dash to your defroster, then there is a bad check vavle or vacuum leak as TPSDODGE stated.
