Chk Eng Light
Old Jul 22, 2006 | 07:51 PM
cgb864's Avatar
cgb864
Default Chk Eng Light
Just did a search here for codes and clearing codes but didn't see what Im specifically looking for.
Apparently too the Auto-Zones now have a policy of NOT RESETTING CODES (at least here in Arlington Tx) as they checked it and say that it was "multiple cylinder mis-fires."
Now we just changed the plugs (installed Autolite Platinum's) and it's been running just fine. Took it off-road yesterday, got it kinda hot (it's 105 here) although it still runs normal at normal temps now, just has the CE light on.
I tried turning the ignition on and off (w/out starting) several times with no joy.
Aside from buying a code meter (which I will likely do anyway) how do I clear the code and get the light out?
Old Jul 22, 2006 | 08:08 PM
bamory's Avatar
bamory
Default RE: Chk Eng Light
They normally reset the trucks, but you just unhook the battery for about 15 minutes
Old Jul 22, 2006 | 08:12 PM
cgb864's Avatar
cgb864
Found this site http://dodgeram.org/tech/gas/Trouble/pcm_fault_code.htm and printed off the directions. I started it and wouldn't ya know the CE was now off.
Thanks for the response.
