Need Brakes, HELP!!!
Old Jul 25, 2006 | 08:22 PM
2big2dodge's Avatar
2big2dodge
Default Need Brakes, HELP!!!
Well my truck needs new brakes, so is it hard to do or can i do it? Where should i go to get them and what should i get?
Old Jul 25, 2006 | 08:43 PM
steve05ram360's Avatar
steve05ram360
Default RE: Need Brakes, HELP!!!
powerstop cross-drilled rotors & powerstop pads from summit racing... you wont be disappointed.
Old Jul 25, 2006 | 08:53 PM
Tani1500's Avatar
Tani1500
front brakes or rear. the front simple. take the 2 bolts out of the back of the caliber, take it off. take off the rotor, slide the new rotor on, remove the old pads, take a C clamp and a little block or something and push the piston back in, and pop the new ones in. put it all back together. the rear can be a pinta. you can also tighten them more by turning the little wheel on the bottom of the drum.
