re: brtake lights staying on
Old Jul 27, 2006 | 09:50 PM
mudslingertwo's Avatar
mudslingertwo
Default re: brtake lights staying on
mudslingertwo
Student Driver
Status: online I have a 96 dodge ram 4x4 360 auto and the brake lights will not go off unless you lift up on the pedal hard. I have put new pads and shoes and hardware on. New brake light switch and checked the pedal bushings. Does anybody have any answers that could help.
thanks
Post #: 1
RE: brake lights on - 7/26/2006 12:55:09 AM
DieselDemon
Student Driver
Status: offline Sounds like you didn't set the plunger depth correctly.
When you install the switch, you must have the pedal depressed. Go as far as you can. Now install the switch, BUT, make sure you have the plunger ulled out all the way. The switch installs at an angle, then an 1/8 of a turn to lock it. Now let the brake pedal up easy. Don't let it snap back. The pedal will seat the plunger to the correct indent. Try that. I would bet money that's what happened.
(in reply to mudslingertwo)
Report | Post #: 2
RE: brake lights on - 7/26/2006 8:03:35 AM
mudslingertwo
Student Driver
Status: online thanks I will try that and let you know what happens.
I tried this and I found about 1/4 play in the pedal. Is there any ajustments that can be made.
thanks
