1998 Ram 1500 no start, guages not working odometer flashing mileage
Old Jul 29, 2006 | 07:17 PM
cosworth's Avatar
cosworth
Default 1998 Ram 1500 no start, guages not working odometer flashing mileage
1998 dodge ram 1500 4x4 5.2L auto
Engine cranks will not start, have checked the ECM connectors, and a battery disconnect
the guages do not work, all lights come on then go off, but hte abs and airbag and seatbelt ones stay on
engine has no spark
the odometer is flashing the mileage
power goes away from the DLC connector when the key is turned on,
any ideas? im leaning towards the ECM, any input will be greatly apreciated!!!!
Old Jul 29, 2006 | 10:46 PM
The Burning Rom's Avatar
The Burning Rom
Default RE: 1998 Ram 1500 no start, guages not working odometer flashing mileage
Crankshaft Position Sensor..that's my first thought. If the CPS is bad, you won't have any spark. It acts as the pick-up plate for the distributor.
Beyond that, I guess it could be the ECM. I'm not sure what else would cause you to not have spark.
Old May 14, 2015 | 09:54 PM
laramie1500's Avatar
laramie1500
Default fixed
Had that same issue today turned out to be the ground running along the drivers side fuel rail (2 black wires) touched it to the block saw a small spark and my gauges all worked and obdII had power with the key in the on position.
Old May 28, 2019 | 11:51 PM
tenno89's Avatar
tenno89
I hav a 1999 ram 1500 2wd auto 5.9l. My odometer was blinkin after disconnectin th negative battery cable 4 awhile then reconnectin it. Wen i went 2 reconnect it, it sparked/arced really big. Wen i went 2 start th truk again, it cranked a half turn & quit. Like th battery jst went dead. The ododmeter started blinkin wen i turned th ignition on..i researched it & found out tht th pcm went bad wen it arced.
I put on a new pcm (sum1 told me in another forum tht i needed 2 turn th ignition on & wait 15 secs b4 starting it 4 th 1st time after puttin th new pcm in). Only, i 4got tht part. I fired it rite up.
Th odometer still blinks & now th needles jump in time with th odometer on all th gauges. Help!!!
Old May 29, 2019 | 06:54 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I told you the wait 15sec before starting. You may have friend the gauges and might need new ones.
Old May 29, 2019 | 11:10 AM
tenno89's Avatar
tenno89
Wuld tht coz th odometer 2 stil b blinkin???
Old May 29, 2019 | 01:40 PM
MoparFanatic21
If the gauges are fried, yep.
Old May 29, 2019 | 01:50 PM
tenno89's Avatar
tenno89
JUNKYARD BOUND I GESS UGH
Old May 30, 2019 | 07:14 PM
tenno89's Avatar
tenno89
Question....will th odometer read th miles of th truk tht th gauges came out of or my truks miles???
Old May 30, 2019 | 08:02 PM
MoparFanatic21
Yes it will read thr mileage of the truck you take it out of, unless you get a dealer to reprogram them.
