Will CE Codes Reset?
Old Aug 2, 2006 | 12:52 PM
smartobject's Avatar
smartobject
Default Will CE Codes Reset?
Sorry if you've seen this already -- I posted in wrong place at first.
I'm working on a Cylinder 3 misfire P0303 --- After the prob is corrected, will the code be reset on its own after several miles of driving, or do I need to disconnect the battery to reset?
BTW -- I see alot of past posts talking about Cylinder Misfire codes after a plenum gasket replace, and that's what I just finished, too. Any connection?
I have taken out plug 3 and it was dry and white. Will try a new set of plugs all around, reroute the wires according to the TSB and lastly pull the injector(s) and clean. After that, the only thing I know to check is compression test.
Thank you,
Lee
Old Aug 2, 2006 | 02:53 PM
crazy1snow's Avatar
crazy1snow
Default RE: Will CE Codes Reset?
well it will reset if the problem is fixed and you disconnect the battery for awhile. it will come back if the problem is still there.
