Leveling Kit vs. Coil Spacers
Old Aug 13, 2006 | 09:10 PM
2big2dodge's Avatar
2big2dodge
Default Leveling Kit vs. Coil Spacers
Correct me if im wrong but is this now the same thing? just wondering....
Old Aug 13, 2006 | 09:20 PM
ramchrgr88's Avatar
ramchrgr88
Default RE: Leveling Kit vs. Coil Spacers
Yes and no. the more common, less expensive leveling kits are made from coil spacers. THe more expensive ones, you can get as a taller spring. hope this clarifies things for you.
Old Aug 13, 2006 | 11:19 PM
shott8283's Avatar
shott8283
^ bingo
i have coil spacers that gave me 2" of lift in the front AKA leveling KIT
i could have purchased 2" lift COILS for the front and that could be AKA leveling KIT
2 ways to do it.. 2 ways to call it.. totally different but same effect..
Old Aug 14, 2006 | 12:44 AM
Redone4x4's Avatar
Redone4x4
if your lift is all spring in the front, then i believe you could use a 1 or 2" spacer to level the truck out. if you already have a 3" spacer with stock springs, i dont think the leveling kit will work.
Old Aug 14, 2006 | 01:55 AM
rubemeyer's Avatar
rubemeyer
quick question, i was wonderin did you need any type of steering spacer when you put on the coil spacer. ive already got a 3" body lift, and it came with a steering spacer and im not sure ive got another 2 inches of play in my steering rod.
Old Aug 14, 2006 | 03:18 PM
GOD RAM IT's Avatar
GOD RAM IT
no spacer with the steering. Because you are lifting the whole truck with the spacer. With the body lift you just lifted the body which makes the steering shaft shorter.
Old Aug 14, 2006 | 03:23 PM
GOD RAM IT's Avatar
GOD RAM IT
ORIGINAL: Redone4x4
He does have springs in the front. Which means he could add a 5" spacer if he wanted.
If he had the 3" spacer on the springs already then he wouldnt be looking into a leveling kit.
