1997 2500 4x4 front wheel bearings
Old Aug 14, 2006 | 03:40 PM
john dempsey's Avatar
john dempsey
Default 1997 2500 4x4 front wheel bearings
I needed to replace the front unjoints in my axles and since I needed to remove the bearings to get the axles out I thought of putting in new bearings. $400 each!!! Has anyone found them cheaper then $400?
Old Aug 14, 2006 | 08:31 PM
fiveliterbtr's Avatar
fiveliterbtr
Default RE: 1997 2500 4x4 front wheel bearings
FRONT WHEEL bearing, Ram 2500, 7500LB GVW - 4WD, COIL SPRING - 4WD, COIL SPRING 94-99 $367.00 $0.00 $275.25
Front suspension - Suspension components - Front wheel bearing
OR
FRONT WHEEL bearing, Ram 2500, 8800LB GVW - 4WD, COIL SPRING - 4WD, COIL SPRING 94-97 $374.00 $0.00 $280.50
www.makeitmopar.com
One of the sponsors here. 15% shipping charge, so if you got just the 8800lb. bearing, it'd be about $323 shipped. You really need to know someone at a dealer owning either a 2500 or 3500 truck, the stuff is expensive
Old Aug 15, 2006 | 10:43 AM
john dempsey
Thanks Fiveliterbtr. I see your from the Cleveland burbs. I'm in Sagamore Hills.
