factory fog light ?
Old Aug 16, 2006 | 05:30 PM
Tani1500's Avatar
Tani1500
Default factory fog light ?
Im building my new bumper and its going to have hella lights in it. does anyone know if i could cut the wires off my factory fog lights and run the hella's off them. could that handle those lights. Im sure there not that much wattage or anything.
Old Aug 16, 2006 | 05:47 PM
dodgedlr's Avatar
dodgedlr
Default RE: factory fog light ?
the power goes through a fairly heavy relay - so you should be fine.
Old Aug 16, 2006 | 07:54 PM
Sinister's Avatar
Sinister
i would think the wires are fine to swap over to your new lights.
Old Aug 16, 2006 | 10:25 PM
ramchrgr88's Avatar
ramchrgr88
Yes, i have seen it done. one thing that is recommended however is that you splice in a fuse in the wire since the fuse that the fog lights are hooked up to is pretty weak. Again, dont know for certain, i havent tried it, but my dads 98 sport he did that too with some sort of a fancy aftermarket fog light in place and had to put a fuse in line since he kept blowing the one in fuse box. again, we dont know for sure, but it worked....
so i guess you could just wait until its done to see what happens, not like splicing a fuse takes any brains or anything
Old Aug 16, 2006 | 11:19 PM
ElChango's Avatar
ElChango
I agree, you should be safe. I like the additional fuse idea.
But if you want to play it safe, you can always put a relay and activate it through the original wiring.
It should set you back less than 10 bucks in a relay and a couple of wires. I would use 12 gauge wire, Just a thought
Old Aug 16, 2006 | 11:30 PM
Redone4x4's Avatar
Redone4x4
make sure the wire is heavy enough. i used some small guage wire and somehow it burnt up the actual switch itself in the dash.
Old Aug 17, 2006 | 05:19 PM
Tani1500's Avatar
Tani1500
these are the lights imbuilding into the bumper. there only 55 watts so i think they should be alright.
http://www.hella.com/produktion/Hell.../Model_450.jsp
