top gunz
Old Aug 17, 2006 | 12:41 AM
billygoat's Avatar
billygoat
Default top gunz
has anyone used the 2' coil spacers from top gun customz? if so how did you like them. it seems like they are pretty solid and have heard one good thing about them. and they are also cheap, which is a huge plus.
thanks
Old Aug 17, 2006 | 12:44 AM
Tani1500's Avatar
Tani1500
Default RE: top gunz
yes they are good spacers. i think ramsport and maybe shott's are running them? ive never heard of a problem with there stuff. i say go for it the only thing is they will feel like your truck does now. the poly ones reduce alittle shock but not much.
Old Aug 17, 2006 | 01:22 AM
Ram_Sport's Avatar
Ram_Sport
hey sup, they are rigid and beautifully built black i believe powdercoated or sumthing nicely welded, i have the 3" spacer one makes it stand up nice and tough looking no problems with it just a little tough to install cause u gotta be carefull w/ jackstands and pry the axle down to get the spacer and spring to seat in for the first time, its not bad instructions are straight forward everything else is common sense. and ill tell ya what i love the lift looks much taller and may appear stock but pull next to me and be the judge . the polyurethane is no good imho cause they can prly break some time down the road the topgun will hold up a lot better i thinks.
Old Aug 17, 2006 | 04:33 AM
DieselDemon's Avatar
DieselDemon
I have their 3 inch spacer with provisions for dual shock setup. It's a solid product. I also just bought their ladder bars.
Good luck.
