Replacing the serpentine belt
Old Aug 18, 2006 | 04:24 PM
Capepowder's Avatar
Capepowder
Default Replacing the serpentine belt
94 Dodge Ram 1500 4wd, w auto tranny & a/c & No air pump.
I am going to replace the serpentine belt. Anything I should know before I attempt this?
Thanks
Bob
Old Aug 18, 2006 | 04:43 PM
Mayfair's Avatar
Mayfair
Default RE: Replacing the serpentine belt
Check the DIY section. There is a complete set of instructions along with pics.
Old Aug 18, 2006 | 05:30 PM
The Burning Rom's Avatar
The Burning Rom
Nothing special you need to know. Just follow the belt routing diagram when you put it back on. It may take a bit to keep it on all the accessories before you put tension back on the belt, but don't get frustrated with it
It's a LOT more fun on a V10...when you have an air pump...</sarmcasm> [&:]
Old Aug 18, 2006 | 08:35 PM
steve05ram360's Avatar
steve05ram360
while your at it check your belt tensioners for any rough spots when they are rotated... Also you may want to check the actual belt tentioner to ensure it is moving freely. I squirted mine with some wd-40 to keep it loose... there are probably better lubricants than that though... I think it would be gone quickly.
Old Aug 18, 2006 | 09:03 PM
fiveliterbtr's Avatar
fiveliterbtr
ORIGINAL: steve00ram360
Yeah, they're not meant to be lubed...if you get much of any WD-40 thru the seal and into the bearing, it'll wash down the grease, accelerating any wear on the bearing
Old Aug 18, 2006 | 09:10 PM
steve05ram360
it was intended for the spring and the parts that they are in contact with. my spring was sticking so I had to pull the belt back tight after the install. once I sprayed it, it moved much easier and returned to where it should be on it's own.
