Clutch chatter help
Old Aug 23, 2006 | 01:20 PM
MorganM's Avatar
MorganM
Default Clutch chatter help
I just purchased a 2000 V6 Ram 1550 5 speed for $5990 with 66K miles. Everything on the truck is clean and works great. But the only thing I have noticed is when I release the clutch in neutral, the clutch sounds like it is chattering. I think it sounds like a dry throwout bearing but I am no expert. i was wondering if anyone has any knowledge of what this could be. It doesn't make the noise when I push the clutch in.
Thanks
Old Aug 23, 2006 | 01:37 PM
kroffty's Avatar
kroffty
Default RE: Clutch chatter help
Could be pilot bearing in the fly wheel. But most likely it the trans input shaft bearings.
I had a Dakota with the same problem.
If it was the throwout bearing it would make the noise with the clutch pushed in.
Old Aug 23, 2006 | 02:06 PM
MorganM's Avatar
MorganM
Are the trans input shaft bearings inside the trans or outside of it by the clutch?
Old Aug 24, 2006 | 11:41 AM
kroffty's Avatar
kroffty
Sorry to say . But there inside.
I rebuilt my trans and replaced the bearings then. It was a B!tch. And not worth it. next time I will get a junkyard one and try my luck with that.
