MAGNUM
Old Aug 23, 2006 | 01:46 PM
Tommygunz's Avatar
Tommygunz
Default MAGNUM
Did Dodge make a non-magnum 360's in the second gen series? All I seem to see are Magnum badges. If so what are the differences between magnum motors and non. I have a Magnum, but if there really is no dicernable difference or they didn't make anything but that, I guess it's not as special as I thought.
Old Aug 23, 2006 | 02:52 PM
Socha_62's Avatar
Socha_62
Default RE: MAGNUM
Just the sytle of engine. All 2ng Gen rams are Magnum (excluding CTD because I know somebody will want to correct me[:'(]) The Gen 1 rams and V8's in those are the "LA" style engine. The Magnum has a vew slight changes but they're similar
Old Aug 23, 2006 | 03:38 PM
Tommygunz's Avatar
Tommygunz
Default RE: MAGNUM
Thanks Socha
Old Aug 23, 2006 | 06:21 PM
Dtruck96's Avatar
Dtruck96
Default RE: MAGNUM
Alot of stuff is the same. Pretty much the biggest differences are the heads and intakes without getting too technical. However it is possible to interchange alot of parts. I.E make a L.A. engine fuel injected by putting Magnum parts on it. If you have any other questions on them let me know. I have done alot of research on this subject.
Old Aug 23, 2006 | 06:44 PM
shott8283's Avatar
shott8283
Default RE: MAGNUM
heads and intake are different between the magnums and the older LA's the magnum intake bolts go in straight down and the LA go in at an angle.. and the heads flow more in the magnums aswell.. other then some ballencing differences (i think)...they are very similar
Old Aug 23, 2006 | 07:21 PM
Silver_Dodge's Avatar
Silver_Dodge
Default RE: MAGNUM
Don't the Magnums also have slightly higher compression then the LA 318's and 360's due to different piston design?
Old Aug 23, 2006 | 10:23 PM
The Burning Rom's Avatar
The Burning Rom
Default RE: MAGNUM
ORIGINAL: Silver_Dodge
Yup
Old Aug 23, 2006 | 10:36 PM
kayakman's Avatar
kayakman
Default RE: MAGNUM
Go to ----www.allpar.com
