Where did you mount your amp
Old Aug 27, 2006 | 10:43 PM
0DD0DGE's Avatar
0DD0DGE
Default RE: Where did you mount your amp
I mounted one amp behind the driver seat and the other behind the passenger seat. My power wire is ran under the carpet and up behind the back panel into the amps and power cap which is mounted on my box.
Old Aug 27, 2006 | 11:08 PM
HuntinHanson's Avatar
HuntinHanson
is removing the drivers seat as easy as taking out those few bolts in the floor?
Old Aug 27, 2006 | 11:13 PM
shott8283's Avatar
shott8283
yes
Old Aug 28, 2006 | 12:41 AM
Ram1500Dodge's Avatar
Ram1500Dodge
i didnt pull my carpet to run my wires....i just cut a slit in the carpet where i need the wires to come to cut a slit(if needed) from where they were running from and i tightly tape one wire at a time to a straightened out metal coat hanger and pushed it to the other hole and pull them through one by one just like that.....wasnt hard at all.
So would under the backseat be a bad idea?
under the backseat would be fine as long as there is air flow and/or 3 inches of space on each side of the amp
Steve-o
Old Aug 28, 2006 | 03:37 AM
Sinister's Avatar
Sinister
i mounted mine on the rear cab wall, drivers side. predrilled the holes and siliconed them when placing the screws.
the wiring is underneath the plastic piece at the doors., across and then under into the firewall/and up to the stereo.
pics in my gallery for reference.
Old Aug 28, 2006 | 10:52 AM
stnlycup's Avatar
stnlycup
I did mine the same way Tani did his
Old Aug 28, 2006 | 03:30 PM
DuranguenzeRam's Avatar
DuranguenzeRam
Did just about the same except i didnt cut the carpet i just ran them to the amp nobody feet should be in the back of the seat anyway.
Old Aug 28, 2006 | 04:17 PM
crazy1snow's Avatar
crazy1snow
yup i mounted mine under my drivers seat for air flow, just cut a slit in the carpet and ran the wires under the door sil. mainly i did this so i could remove the system without much damage
Old Aug 28, 2006 | 04:45 PM
Tani1500's Avatar
Tani1500
heres mine
[IMG]local://upfiles/15914/77AB8DFF8D0D4157A5136DD36D0CD470.jpg[/IMG]
Old Aug 28, 2006 | 06:45 PM
dodgedlr's Avatar
dodgedlr
My '95 was set up with 2 tens and the amp under the backseat. I had another amp to push the 6x9s in the doors mounted behinde the back seat on the cab wall... be sure to seal your screws with silicone.
The seat comes out with the 4 bolts, use a lifting motion to lift the back part off of "hooks" that anchor it to the cab wall.
