Trans Problem
Old Aug 28, 2006 | 04:24 PM
Socha_62's Avatar
Socha_62
Default Trans Problem
What would a post be with out the story to go along with it?
Last night my buddy convinced me to go down a trail he said wasn't bad at all. At first it was fine but after a few bend on the trail it got narrow as hell and like a 45* angle with loose rocks. Anyways, to steep twist and narrow to back out of I have to go for it. In 4low finially crawl up it with the fricken peddle to the floor. Really hard on it but I made it home with no prob.
Drive to the post office this morning on the way to school, come out and see a puddle. Trans is leaking right under the TC from the little hole on the bottom. Whats wrong and what do I need to fix!!
Old Aug 28, 2006 | 06:06 PM
silverram99's Avatar
silverram99
Default RE: Trans Problem
Sounds like you blew a front seal or something to do with the front pump. Unfortunately to fix it you are going to have to pull the tranny, unless somebody knows a trick to change that seal with out taking the tranny off of the engine. I can't remember if out trucks have an inspection cover on the bellhousing or not. Anyway maybe some one else has a more definite answer.
