tire size on 98 Ram 1500, newb question
Old Aug 28, 2006 | 07:27 PM
bfalcon's Avatar
bfalcon
Default tire size on 98 Ram 1500, newb question
I was just wondering what the largest tire size would be to fit on a 98' Ram 1500 crew cab, 2WD. My tires are currently stock size and worn out. I need to put on some new tires and figured I would go ahead and put the larger tires in, but at the same time, don't want to spend money on Suspension or body lifts. Thanks in advance for any help and advice!
Old Aug 28, 2006 | 09:39 PM
kayakman's Avatar
kayakman
Default RE: tire size on 98 Ram 1500, newb question
My 98 ram quad cab came with p-245/75-16 which was an option for us Canadian guys. I now have Kelly LT-245/75-16 load range C.
Old Aug 28, 2006 | 09:40 PM
The Burning Rom's Avatar
The Burning Rom
265 if your gear ratio is 3.55
MAYBE 285 if your ratio is 3.92 or 4.10...the 285s would probably rub a bit.
Old Aug 28, 2006 | 11:42 PM
bfalcon's Avatar
bfalcon
I have no idea what my gear ratio is, everything in my truck is stock, so I'm guessing they are the same ones that came with the truck. So I should be able to put on 265's comfortabely with stock gears then?
Old Aug 29, 2006 | 01:45 PM
Chopper1's Avatar
Chopper1
Yes. I gave a friend of mine the 265/16's off my 97 sport for his 96 2WD. Same body. Fit well.
Old Aug 29, 2006 | 02:07 PM
Mayfair's Avatar
Mayfair
I just put 265's on my 98 Ram mounted on 17" rims and they fit fine. I'm not sure what gears I have, but it seems like I'm winding a bit more at 70 mph.
WAIT ... I'm sorry I just realized that you have a 2wd. My Ram is 4wd.
