Fuel Injector Numbering
Old Aug 29, 2006 | 12:54 PM
Brad426's Avatar
Brad426
Default Fuel Injector Numbering
Have you ever done something and wondered what was I thinking?
I removed my 5.9 from a 2001 Ram 1500 for painting and detailing. I was cleaning the wire engine harness and noticed that 3 of the 8 fuel injector leads had number tags on them. Duh. How can I tell which lead plugs into which cylinder injector? Are the leads color codes to each cylinder? Thank for your advice.
Old Aug 29, 2006 | 01:32 PM
steve05ram360's Avatar
steve05ram360
Default RE: Fuel Injector Numbering
the injector plugs will only go 1 way... it might be hard to get them backwards. if your wanting to know about the wiring color codes, download the manual and have a look. the manual can be found in one of the threads at the top of this forum (tacked).
Old Aug 29, 2006 | 02:00 PM
Brad426's Avatar
Brad426
Thanks Steve. I realize that the plugs only fit on the injector one way and that there is a mechanical lock of red plastic. I guess I should of been more clear in my question. Does it matter which lead goes on which injector? If so, how can I tell if the factory lead number decal (tag) is missing from the lead? Thanks.
Old Aug 29, 2006 | 02:08 PM
steve05ram360
yeah it does matter however what i'm saying is when you lay the harness down the length of each injector plug will only allow it to go on one injector. even if you took the harness out entirely, it would be hard to get it wrong when it comes to the injectors.
Old Aug 30, 2006 | 12:38 PM
Brad426's Avatar
Brad426
That was my first choice as you discribed. I figure if I was wrong it would not run well. I look at the wires of each injector plug last night. They are all the same. One brown & one green with an orange stripe.
Old Aug 30, 2006 | 01:32 PM
steve05ram360
when you lay the harness back down onto the motor you'll see where they go...
btw, you yanked your motor for detailing?
Old Aug 30, 2006 | 04:58 PM
Brad426's Avatar
Brad426
I had the truck painted FJ6 Sassy Grass Gree like my 70 Cuda was. I wanted to detail under the hood and try(try) and make the color change look factory. I'll send you some pics if your interested. I don't know how to post on here yet. My address is bradallore@sympatico.ca
Thanks Eh!
