water pump question
Old Aug 29, 2006 | 07:12 PM
RamHead21's Avatar
RamHead21
Default water pump question
i have a 98 ram 1500 with a 360 and the water pump went out. when i called the parts store they asked if it was a bolt on or a press on pulley. how do i know what i have? anyone have a pic or can someone explain? thanks
Old Aug 29, 2006 | 10:35 PM
The Burning Rom's Avatar
The Burning Rom
Default RE: water pump question
If there are 4 bolts holding the PULLEY (not the fan or clutch) on, then you have a bolt on. If you don't see any bolts, and the face of the pulley is smooth, then you have a press on.
Old Aug 29, 2006 | 10:37 PM
RamHead21's Avatar
RamHead21
awesome thanks alot. how come there are two different kinds?
Old Aug 30, 2006 | 03:46 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
i should also mention that when you do it yourself (we do have a DIY in the DIY section thanks to steve) that some clutch fans are left handed threads, and some are right handed...[&:]
Old Aug 31, 2006 | 03:41 AM
RamHead21's Avatar
RamHead21
well thanks for the info. not real sure what i should do. i've only changed the oil and replaced the battery in a vehicle before...so not real sure if i should be trying it replace the water pump by myself. anyone know any good, honest, mechanics around the fort worth area that aren't gonna charge me an arm and a leg?
Old Aug 31, 2006 | 03:24 PM
azffighter's Avatar
azffighter
I've done mine before and it's really not that hard, just alittle time consuming. Make sure your read what you need to do first and don't forget to replace the seal as well.
