Swapping gauge cluster
Old Sep 6, 2006 | 06:55 PM
Tommygunz's Avatar
Tommygunz
Default RE: Swapping gauge cluster
Yup, mechanical odo and trip, both on the display. So I read your post silver. If I got a better cluster, it should hook up, just the mileage will be off then? Can any dealer rep or mech tell me whether it is for sure adjustable at the dealership or not? Has anyone else seen my cluster, mechanical odo and no tach?
Old Sep 6, 2006 | 07:03 PM
Mayfair's Avatar
Mayfair
ORIGINAL: Silver_Dodge
The odometer can display values up to 499,999
kilometers (499,999 miles). The odometer latches at
these values, and will not roll over to zero.
Wow that kinda bummed me out. I was looking forward to seeing a million miles on my Rams odometer someday. [sm=boosign.gif]
Old Sep 6, 2006 | 07:18 PM
Silver_Dodge's Avatar
Silver_Dodge
The service manual doesn't seem to indicate that the mileage can be changed. I would bet it probably can't, probably illegal to do so. Since yours is a '97 with mechanical odometer, i'm not sure if you could even use a cluster from a 99-01 with the Vacuum Fluorescent Display(VFD). If you can, you might just need to search for one that has mileage close to yours.
Old Sep 6, 2006 | 07:29 PM
Tommygunz's Avatar
Tommygunz
Called the local stealership "Lithia" They said I would likely need a new PCM as well to make the cluster function properly, even if I got one from the the same model year. Guess I8 will just buy an aftermarket tach and install that.
Old Sep 6, 2006 | 08:15 PM
Silver_Dodge
That doesn't sound right to me, but whatever. I'm going to try to get that cluster I mentioned for mine, and see if it works. I'll let you all know how it goes in a few weeks.
Old Sep 7, 2006 | 01:04 AM
shott8283's Avatar
shott8283
hey silver,,, you could just swap in the cluster then if you sell the truck..swap in the old one or just tell the new owner what had happend..
and IIRC its a federal offense to tamper with vehicles odometers... felany i belive... could be wrong tho
Old Sep 7, 2006 | 01:10 AM
nmason's Avatar
nmason
my 96 used to have the speedo/giant fuel guage. i swapped it with guages from a 94 that had a tach. just hooked it up and it all worked, 100%. i am now 14000km over what the truck actually is.
Old Sep 7, 2006 | 12:42 PM
Silver_Dodge
ORIGINAL: shott8283
....... its a federal offense to tamper with vehicles odometers... felany i belive... could be wrong tho
Well, I guess I better find out for sure about this before I do anything. If that is true, that sucks. I hate how aftermarket tachs look, I was hoping to stick with the stock look.
I might take my gauge cluster out this weekend and see if it would be possible to transfer the odometer circuit board to the new gauge cluster. That way, I have not changed the odometer on the truck, only the gauges around the odometer.
Old Sep 7, 2006 | 12:52 PM
dodgedlr's Avatar
dodgedlr
When we order NEW replacement clusters, we have to initial a legal document disclosing the actual miles on the vehicle.
Then the factory ships out a new cluster with that mileage programed into it.
There is no way to change this.
Old Sep 7, 2006 | 01:03 PM
Silver_Dodge
I see. Ok. Would you do this for a customer who just wants to change to a different gauge cluster, or will you only do it if something is actually wrong with the original cluster and it must be replaced? What is the ballpark cost of this?
