spark plug an wires
Old Sep 7, 2006 | 05:20 PM
whiteram00's Avatar
whiteram00
Default spark plug an wires
i just picked up a set of autolite spark plugs for my 00 ram 5.2,now what is a good brand of plug wires at a decent price,the plugs are pre gap at 44,what is the best gap for them
Old Sep 7, 2006 | 05:37 PM
Silver_Dodge's Avatar
Silver_Dodge
Default RE: spark plug an wires
Gap depends on if your running stock ignition or not. If you are, and the plugs are 3923's, gap them at about .038. If they are 3924's, gap them to the factory spec of .040. I run Mopar Performance wires that are 7.5mm. Stock wires should be fine for you though. Otherwise, Taylor wires are pretty decent usually.
Old Sep 7, 2006 | 05:43 PM
whiteram00's Avatar
whiteram00
is it a must to replace cap an rotor button while changing wires an plugs
Old Sep 7, 2006 | 05:53 PM
silverram99's Avatar
silverram99
ORIGINAL: whiteram00
Its not a must but you are there, so you might as well. Be sure to get brass terminals too, go to NAPA or Oriellys. NOT AUTOZONE lol. The only thing I can build off of what SilverDodge said is if you are planning to upgrade your ignition any time soon, you might want to consider getting better than stock wires. The Accel ones I have were like 80 bucks but you could get the cheaper SuperStocks, they are like 40 I think.
Old Sep 7, 2006 | 05:56 PM
Silver_Dodge
No, but it is a good idea. It is far more likely that your cap and rotor needs changing then your wires, unless you know for sure your wires are compromised somehow. Anytime I do my plugs, I also do cap and rotor (about every 25-30k miles).
Old Sep 11, 2006 | 09:17 PM
whiteram00's Avatar
whiteram00
well i changed the plugs an wires an set the gap at .040,the stock or whoever replaced them last set them at.070 i had a bad miss but now its gone an runs ten times better,does factory set them at .070 or just someone that didnt know no better,an im changing the cap an rotor button next payday
Old Sep 11, 2006 | 09:28 PM
TMS Bill's Avatar
TMS Bill
The electrodes erode away as they are used. The longer they're in there ... the fatter the gap.
