one ton wheel cylinder swap
Hi, I did the chevy one ton wheel cylinder swap on my 96 1500 Ram 4x4 I think I'm going to like the improved braking, but my brake light and ABS light are now on. Wondering if any of you guys could give me some ideas on how to get them to go off. Thanks for any ideas.
If your Brake light is on its most likely air in the system. As far as the ABS light not sure I believe the sensor picks up in the diff. so that shouldn't make a problem when changing w/c. might want to have it scanned to see what code it is setting.
Thanks for the help you were right I bleed the brakes again. put about a quart of fluid through it and now lights are off. Now just have to drive it around a bit to see if this mod was worth doing.
