IAC Question
Old Sep 14, 2006 | 02:09 PM
hilliad's Avatar
hilliad
Default IAC Question
If I install a new IAC, do I have to remove the throttle body or can I just remove the screws on the old IAC and install the new one.
Old Sep 14, 2006 | 02:23 PM
shott8283's Avatar
shott8283
Default RE: IAC Question
na.. you shouldnt have to remove the TB.. i bet you could get in there with a torx driver and get it out.. becarefull.. they are threadlocked so they are gonna be tight to undo at first...
Old Sep 14, 2006 | 03:56 PM
hilliad's Avatar
hilliad
Thanks for the help. Where is the best place to buy one? Autozone has the Wells brand for about $46.
Old Sep 14, 2006 | 07:10 PM
tom d's Avatar
tom d
You don't have to remove the tb, but if the end of the IAC has a bunch of carbon you will need to clean the tb hole pretty good, a lot easier with it off. Only four bolts and a $1.50 gasket. Mine would idle fine but try to die for a second if I took my foot of the gas quick. Replced the IAC a couple of times before I figured out it was running rich and getting a black sooty build up where the IAC seat in the tb. Took it out, cleaned it up, ran fine.
