Running rough
Old Sep 15, 2006 | 08:50 PM
Kevster324's Avatar
Kevster324
Default Running rough
I have a 99 Ram 1500 with the 5.9L. Sometimes after running awhile, when I let the truck sit for about 20-30 minutes, it idles rough then runs rough after I put it in gear. It has a hesitation at first, then runs ok after I drive a hundred feet or so. Kinda weird. Any help?
Old Sep 15, 2006 | 09:00 PM
BIGSEXY's Avatar
BIGSEXY
Default RE: Running rough
Maybe try some injector cleaner.
Old Sep 15, 2006 | 10:13 PM
The Burning Rom's Avatar
The Burning Rom
Clean out your idle speed motor/control/whatever you wanna call it....the IAC...it's on the side of your throttle body. Also check your coolant temperature sensor. They're the two sensors that regulate idle once the truck is warmed up.
