MY hood is stuck
Old Sep 18, 2006 | 05:06 PM
petrucci's Avatar
petrucci
Default MY hood is stuck
I have a 1997 Ram 1500 with the 318. When I try to release my hood it feels likw the cable is active but the hood will not release to the safety latch position. I can reach my arm up through the fog light opening and manually pull the safety release but the hood is still stuck. Any suggestions where I might try to pry this thing open at without damaging anything ?? Thanks in advance.
Old Sep 18, 2006 | 07:06 PM
silverram99's Avatar
silverram99
Default RE: MY hood is stuck
You might try making a fist and hitting the top of the hood while you get a helper to pull the latch from inside the truck. I have done this on other vehicles in the past, just depends on how bad it is stuck.
Old Sep 18, 2006 | 09:47 PM
Big_N_Bad's Avatar
Big_N_Bad
yea dude just pull up on the hood. It happened on my subaru, it would unlatch but then it wouldnt pop up. so i just pulled it up then it came. once i got it opened it sprayed it with wd-40. never stuck again Hope this helps
BNB
