best brake rotors
Old Sep 21, 2006 | 09:52 PM
ddog737374's Avatar
ddog737374
Default best brake rotors
ok well im going to need to upgrade my front brake rotors to a high perfomance one so i can brake better anyone know of a good kind that well help stop my 35s beside a full brake upgrade.
Old Sep 21, 2006 | 10:59 PM
DieselDemon's Avatar
DieselDemon
Default RE: best brake rotors
Bendix severe duty slotted rotors, and a set of Duralast Gold carbon/metallic pads. A good pad and rotor combo that work VERY well together. I personally avoid cross drilled unless it is the setup where the rotor has 5 or 6 slots, and only 3 holes between each slot. That is a nice setup, IF, it's ordered in the severe/heavy duty version. The rotors with the "swiss cheese" look can tolerate heat, but now you have about 10,000 times the surface area for corrosion to set in. And in heavy brake applications, they have been know to warp as bad as unslotted/cross rotors. And one good salty winter speeds up the corrosion process.........lol. Just be more educated when you go to the parts store. Most if the time they assume slotted/crossed ARE heavy duty. Not necessarily.
The trick to Dodge Ram brakes is keeping the bushings and slider pins greased well. I do my truck three times a year.
Just my opinion.
Good luck.
Old Sep 21, 2006 | 11:28 PM
superdak05's Avatar
superdak05
www.ssbc.com great place for upgrades or slotted rotors and pads.
Old Sep 21, 2006 | 11:30 PM
The Burning Rom's Avatar
The Burning Rom
If you're looking for improved braking, you should definitely look into upgrading your rear wheel cylinders
Old Sep 21, 2006 | 11:34 PM
shott8283's Avatar
shott8283
i have SSBC's rear discs on my truck and they friggen rock.. all their stuff is awesome quality.. and on top of that they are only like 20 mins away from me.. so your buyin good ole' NY quality
on my fronts i have the crossdrilled rotors from summitracing .. they are the SR's brand cheepo's that were on clearence a month or so ago.. 50 bux a peice.. and got some EBC green stuff pads.. the combo is "ok" .. wish i would have done 2 things different .. 1;;; bought better brand rotors,, 2::: bedded in the brakes correctly..
they stop great.. its just tha tsince i live in the salt belt during the winter i shouldnt be expecting long life out of these rotors.. i might go slotted next time or just some OEM style napa replacements.. that pads rock!!! no brake dust.. which is nice on my new alumm rims!
Old Sep 22, 2006 | 08:08 AM
vsraptor's Avatar
vsraptor
I have replaced my brakes and the wifes{2002 gand am} with MORSE-CERAMIC. No faults yet. and alot cleaner rims. now i need to wash her rims off. MAYBE some day i will get the old brake dust off of her hub caps.
Old Sep 22, 2006 | 11:12 AM
turkeyhunter1962's Avatar
turkeyhunter1962
I have looked all over the internet and have been unable to find these upgraded rear wheel cylinders - Anyone know where you can get these for my 01 4X4?
Old Sep 22, 2006 | 12:41 PM
RamOwna's Avatar
RamOwna
ORIGINAL: superdak05
that link sent me to a South Shore baseball Club website.... [sm=offtopic.gif]
Old Sep 22, 2006 | 01:44 PM
shepard's Avatar
shepard
turkeyhunter, the cylinders are spec'd for a '90s GM 1 ton. I used the '95 GM 1 ton dually 4x4 spec at the parts store. They just have a bigger bore. Cost about $11 each.
Old Sep 22, 2006 | 02:12 PM
turkeyhunter1962
Does this look like what you mean:
http://www.napaonline.com/masterpage...ylinder+-+Rear
Vehicle: 1995 >> GMC Truck >> K3500 1 Ton 4WD -
Pickup w/ Dual Rear Wheels
Wheel Cylinder - Rear
Item#: UP 37337
Price: $12.49
Attributes:
Bore Size:1 3/16"
Features & Benefits:Application Engineered to Meet or Exceed Original Equipment Design & Quality. Rubber Components are Made from EPDM (Ethylene - Propylene - Diene- Monomer) & SBR (Styrene-Butadiene-Rubber).
Features & Benefits - 2:Wheel Cylinder Rubber Components Meet SAE J101 Specifications to Ensure High-Temperature Durability.
Material:Rubber Components Made from EPDM Rubber Ensure Resistance to Dryrot & Ensure Compatibility With Silicone & Glycol-Based Brake Fluids.
[IMG]local://upfiles/35230/FC028D7F6AEC492AB27A7AC8CC8A837E.jpg[/IMG]
