i did it .......but.......
Old Sep 24, 2006 | 02:46 PM
vsraptor's Avatar
vsraptor
Default i did it .......but.......
i did the rear wheel cylinder swap with much ease. i only had to remove the smaller rear spring on the driver side.It was a little tricky getting in place with the plunger shafts but i made sure it worked before i but it all back together. But i did not really notice a difference. I still have to push a little far on the pedal before i start to stop. Anyone know why?
Old Sep 24, 2006 | 02:49 PM
HuntinHanson's Avatar
HuntinHanson
Default RE: i did it .......but.......
maybe some air in your brake lines? are you sure they were bled well? Maybe a weak master cylinder?
Old Sep 24, 2006 | 02:52 PM
vsraptor's Avatar
vsraptor
i plan on doing the bleed again. I changed the master cylinder four months ago when i got worried about the soft pedal and it did not help then.
Old Sep 24, 2006 | 06:49 PM
silverram99's Avatar
silverram99
Did you bench bleed the new master cylinder?
Old Sep 24, 2006 | 07:11 PM
974x4's Avatar
974x4
might be the booster if its a fadin pedal. check for leaks and blead it again.
Old Oct 2, 2006 | 09:48 PM
TMS Bill's Avatar
TMS Bill
This might be a little late (just got back off of two weeks leave) but how well did you adjust the rears? Mine had to go out pretty far. QUICK response on the pedal.
