Soft ticking noise from under hood
Old Sep 26, 2006 | 01:48 PM
ripto's Avatar
ripto
Default Soft ticking noise from under hood
It sounds like theres a soft ticking noise comin from underneath my hood anytime I step on the gas. Can't hear it at idle, can't hear it when I'm coasting, only when accelerating. Now I've only began to hear this noise recently when I've had to drive with my windows up (getting cold). I did install the FIPK this summer. Could that noise be the normal functioning noise of the FIPK, or could it be something else?
Old Sep 26, 2006 | 02:24 PM
Socha_62's Avatar
Socha_62
Default RE: Soft ticking noise from under hood
Probably just your lifters and valve clatter. I ran some Marvel Mystery Oil through mine and quited it right up.
Old Sep 26, 2006 | 05:56 PM
silverram99's Avatar
silverram99
ORIGINAL: Socha_62
Or a small exhaust leak. With it running at idle carefully run your hand around the exhaust manifolds and feel for a pulse of air. Then feel around the collectors where they bolt to the exhaust manifold.
Old Sep 26, 2006 | 08:37 PM
ripto's Avatar
ripto
ORIGINAL: silverram99
I don't know too much about trucks yet but the spot your talking about, is that like where the pipes from the cat meet the engine?
Old Sep 27, 2006 | 02:17 AM
dirty dog's Avatar
dirty dog
probably is the valves my truck is doing it to and i cant find nothing to make it quit i run a bottle of lucas every time i change my oil
where do you get this mystery oil you were talking about and what is the name of it?
Old Sep 27, 2006 | 02:55 AM
ChaoticBastard's Avatar
ChaoticBastard
Marvel Mystery Oil.Any store really.Walmart even has it.Comes in quarts or gallons I believe.Its 3.50 a quart I think.Good stuff
Old Sep 27, 2006 | 02:59 AM
ripto's Avatar
ripto
What, you mix this with the oil whenever you add/change it?
Old Sep 27, 2006 | 06:23 AM
silverram99
ORIGINAL: ripto
Yes where the pipes meet the exhaust manifolds, which are the big rust colored things on each side of your engine. You will probably have to crawl under the truck to be able to feel them.
Old Sep 27, 2006 | 01:53 PM
Ram_sport96's Avatar
Ram_sport96
thats what was causing the ticking in my truck... little exhaust leaks in the headers...
