1999 Ram 1500 Steering Problem
Old Sep 26, 2006 | 06:32 PM
2004HemiRider's Avatar
2004HemiRider
Default 1999 Ram 1500 Steering Problem
Hello,
My wife has a 1999 Dodge Ram 1500 and when you step on the gas from a stop, the steering has a weird feel. It feels like something is loose and
ratcheting and expanding.
When you come to a stop it feels the same as if something is ratcheting and colapsing.
We have had this to several places to look at, but everyone says everything in the suspension is tight.
Does anyone have any ideas what to look for?
Thanks in advance
David Rider
Old Sep 26, 2006 | 07:03 PM
The Burning Rom's Avatar
The Burning Rom
Default RE: 1999 Ram 1500 Steering Problem
2wd or 4wd?
Old Sep 26, 2006 | 09:49 PM
DADDIEMIKE's Avatar
DADDIEMIKE
SOUNDS LIKE THE INTERMEDIATE STEERING SHAFT . IT IS THE ONE FROM THE STEERING WHEEL TO THE STEERING BOX. GRAB IT AND SEE IF YOU CAN MOVED IT AROUND ANY. MY 01 DID THE SAME THING. IT WEARS ENOUGH TO FLOP AROUND INSIDE OF ITSELF. YOU CAN HAVE YOUR WIFE SET IN THE TRUCK AND HOLD THE WHEEL AND BOUNCE THE FRONT END AND SEE IF SHE CAN FEEL IT.
Old Sep 26, 2006 | 10:58 PM
2004HemiRider
It is 4WD, I can not feel anything if I move the Shaft ARound, Next get the wife in the car and start rockin.......
Old Sep 27, 2006 | 12:37 AM
DieselDemon's Avatar
DieselDemon
Could be a worn steering gear, a worn/loose pitman arm. Make sure the steering gear bolts are torqued properly. There should be three. And you said all the suspension was tight.
The only other thing I can suggest, cause it happened to me, it to make sure your LOWER control arms do not have bad alignment bolts. The bolts have lobes on each side. One lobe is welded to the bolt, the other lobe ( at the nut end) is a shaped fit that slips on. They wear out, and now you have some axle slop. You would have to be pretty strong in the arms to move it arond by hand. Even the alignment guy may miss it. But in reality he should catch it because it would be impossible to set and retain the proper caster. If you have to replace them, have a guy tac weld the lobe to the bolt. NOT THE NUT!!!.lol.
Ever been in a front end accident? Even a slight collision could break the steer gear. Check the power steering fluid for metal filings. I am pretty sure you have a Saginaw series, ps pump. There's a magnet inside so you'll have to swipe a finger inside the reservoir and take a "pap smear" from it to check for filings...lol.
Good luck.
Old Sep 27, 2006 | 12:42 AM
shott8283's Avatar
shott8283
ORIGINAL: DieselDemon
Good luck.
raw dude .. lol
are your tie rod ends good? do they have play or loose?
