Ring gear for differential???
Old Sep 26, 2006 | 10:35 PM
clark84's Avatar
clark84
Default Ring gear for differential???
I cant seem to find anywhere where i can get just a ring gear, not a ring and pinion. I only need the gear. is there any way I can get just the gear? how much is is it to get it re-manufactured? any help would be awesome!! im at a loss here.
Old Sep 26, 2006 | 10:50 PM
robert97dodge's Avatar
robert97dodge
Default RE: Ring gear for differential???
ORIGINAL: clark84
Your not gonna be able to get just a ring gear. When you replace one you have to replace the other. Each set of gears is gonna wear a little different and if they R&P dont match up right then they could wear out quicked and cause problems. What gears you looking for and for what axle?
Old Sep 26, 2006 | 10:54 PM
clark84's Avatar
clark84
for a 98 with the 8.25 app. and 3.55 gear. i dont know what axle. part #3507647-3.55
Old Sep 26, 2006 | 11:32 PM
robert97dodge
ORIGINAL: clark84
If this is for your Ram 1500 4wd then you have a chrysler 9.25 in the rear and a D44 in the front. If this is for your ram that you are running 35's on why dont you go ahead and get some 4:56 or 4:88 gears. You will have to do the front and rear but it will worth it. You will getter better power and be able to pull more.
