Hypertech Programmer or Mopar PCM
ORIGINAL: The Burning Rom
The hypertech WILL NOT allow you to reprogram for tire size on the 97 Rams. The 97s use a gear in the rear end to determine speed. The hypertech will only do tire size on the 98.5 and newer Rams.
not tryin to jack the thread here or go offtopic, but real quick- is that just 97 rams, or all rams BEFORE 97??
ORIGINAL: jnellydodge
How much were your Mopar PCM's for those of you that have them???
ORIGINAL: ripto
What kind of improvements did you notice after putting in the Mopar PCM?
ORIGINAL: 360sport
I saw the one in your thread of PCM's that are on eBay. The one for the 97 is for the 318. Is there a difference between the 318 and the 360 PCM? My guess is there is since that one is specified for a 318.
Doesnt Hughes or KRC offer a reflash service for the stock ECM?
ORIGINAL: muddy_blue_dodge
Would a 97 PCM work on my 2000 318? I like my Hypertech I could really tell a difference in my truck after I keyed it in. Better accel and gas milage. If memory serves me correct I got almost about 1.2-1.3.
ORIGINAL: Redskin57
No...there were changes made in mid 98. A '99 PCM would PROBABLY work. No gaurantees there though.
ORIGINAL: Redskin57
ORIGINAL: 360sport
Do you know which years would work on the 97? I am going to guess only 97 since it may have been the first year w/OBDII and the last year with that analog style dash?
ORIGINAL: Redskin57
ORIGINAL: 360sport
Do you know which years would work on the 97? I am going to guess only 97 since it was the first year w/OBDII and the last year with that analog style dash?
The analog dash was used up until 98.5. The '96 PCM might work in the 97, but I can't say for sure. Those first few years were sort of questionable as to how much they had actually switched over to OBDII. I like to call it OBDI.5 [8D] I know it's the same way with a lot of cars. 95, 96, and sometimes 97 models tend to have electronics that are unique only to each year.
when i was rebuilding the motor for my truck i had called and talked to some one at KRC about a reflash for mine [96 5.9 ] and if i remember right i think they could do reflashes on 95 and newer.
