2nd Gen ball joint replacement
Old Oct 2, 2006 | 03:10 PM
mbaz's Avatar
mbaz
Default 2nd Gen ball joint replacement
Maybe it's coincedence but after my wife running over a deer my truck pulls to the right like it's looking to finish the job. I took it in for an alignment and saw that I've got a bad ball joint. Sometime soon I'll replace them all with something with a zirk fitting (sounds like Moog is a good choice). Besides rubber is there anything else I should look at/replace while it's all torn apart. I have the service manual (thanks steve00ram360 https://dodgeforum.com/m_340929/tm.htm) and a ball joint replacement sheet ( http://www.pavementsucks.com/tech/balljoint.php ). It sounds like the ball joints can be a weak link, anything else I' missing?
Old Oct 2, 2006 | 03:20 PM
Tani1500's Avatar
Tani1500
Default RE: 2nd Gen ball joint replacement
if your gunna be in there anyway might as well do the u joints, hubs if there bad. i just did my ball joints about a month ago.
