nurf bars with a body lift
Old Oct 4, 2006 | 11:19 PM
ddog737374's Avatar
ddog737374
Default nurf bars with a body lift
i was thinking of getting some nurt bars but i have a 3 inch body lift on will it still work and look ok?
Old Oct 4, 2006 | 11:28 PM
Ram1500Dodge's Avatar
Ram1500Dodge
Default RE: nurf bars with a body lift
ive been wondering the same thing....never really looked out how they mounted, is it a specific location or can they be placed closer to the body.....hopefully someone will have the knowhow
Old Oct 4, 2006 | 11:52 PM
TMS Bill's Avatar
TMS Bill
My nerf bars mounted by using two cab bolts (per side). On a BL truck, they would mount between the spacers and the cab. Don't see why it wouldn't work.
I guess you COULD mount them under the original frame tabs but I think that would look kinda goofy. My support straps bolted directly to the body, too (had to drill). They would be too short if the bars were mounted to the frame.
Old Oct 5, 2006 | 12:25 AM
Tempsho's Avatar
Tempsho
Some nerf bars are mounted on the body mount brackets and some nerf bars mount right on the body itself. I have the original Mopar nerf bars which mount on the body. All depends on the style. The ones that use the body mounts dont move with a body lift.
Old Oct 5, 2006 | 01:29 PM
Chopper1's Avatar
Chopper1
Look at my pics in the gallery. I have a 3" body lift and Westin bars.
I think it looks OK. The wife was happy that her step is not higher. She doesn't know that the new lift will be on in a month or so. I already have the 37" Baja Claws and she has yet to figure out why they are not already on the truck. I told her that I want to clean up the wheels and suspension first, and so far she is buying it. The only problem I could see other than ground clearance not changing is that a small kids foot could slip through the gap and hurt real bad if they fell.
Old Oct 5, 2006 | 02:35 PM
Socha_62's Avatar
Socha_62
If would work, you'll just have to put the bars on top of the BL blocks. Probably have to make the support straps a diffrent legnth too.
