alternator amps?
Old Oct 5, 2006 | 08:59 PM
jscherencel's Avatar
jscherencel
Default alternator amps?
Is there a place to look on our trucks to find out what the amps of the alternator is? I tried looking at the label and the only thing I know is 12v and a bunch of serial numbers.
Old Oct 5, 2006 | 11:26 PM
Socha_62's Avatar
Socha_62
Default RE: alternator amps?
1500,2500,3500? V8?
Most are 136 Amp if I remember correctly. Search this forum for "build sheet" and you'll get a link to a chrysler site that will ask for your VIN. Fill out the form and email it to them, they should get back to you quickly with all the stuff that your truck came with
Old Oct 5, 2006 | 11:59 PM
DieselDemon's Avatar
DieselDemon
I think the diesels were only 120 or 160 amp. I would think a gasser is a little lower than 120. Proabaly in the 80-100 amp range.
Old Oct 6, 2006 | 01:04 AM
Socha_62's Avatar
Socha_62
Mines a 136A, have it here on the build sheet.
Old Oct 6, 2006 | 07:17 AM
HankL's Avatar
HankL
some part numbers from an older post:
Subject: Re:Will high amp 53008651 alternator bolt on in place of
smaller ones? (welder-generator?)
Hank, I have swapped out the two differnt alternators
a few times without any problem. The one that's on the
motor right now is a 53027913, ans the spare in the
tool box is a 53008651. I don't even remember what
came stock on my truck.
--- Henry wrote:
> Will the larger 120 amp rated Ram pickup alternator
> bolt on in place of the
> lower amp rated alternators on the gasoline V8s ?
> Anyone do this swap already?
> On my 1995 alternator the nameplate says:
> 53008647
> 121000-3470 12V
> Family 90HS
> Denso
> Made in Japan 70113
> On page 8B-10 on the 1995 FSM it says the
> Denso 53008651 is rated 120 amps and has 7 grooves,
> whereas the 53008647 of Family 90HS is only rated 90
> amps.
> It also says the diesel has 8 grooves and is
> 56027221
Hank , I think you brought this up a few weeks ago. It piqued my
curiousity. The '98 Jeep Grand Cherokee 5.9V8's did come with a 150 amp
alternator from the factory. I'm guessing it had largely to do with the
electric fan that they also came with. I just picked one
up to see if it would work on my Dakota. The answer is, no for any vehicle
before 1998. Different
connectors than on my '95. I thought there had been a switch in terms of
connectors
at some point and it turns out that it was in '98 and up. The part number
for anyone that is curious is 56041394AA for this piece.
Old Oct 6, 2006 | 07:48 AM
habeba86's Avatar
habeba86
I have a 117 amp in mine.
Old Oct 6, 2006 | 10:55 AM
DieselDemon
Company in Texas makes a 208 for the Ram CTD. I have one in my truck and so far it has performed flawless. Just remember to remind the guy that the diesels have an 8 grove pulley. I run two amps at just about 1300 watts RMS. Headlights on, AC blastin, fog lamps, etc. My voltage NEVER drops below 13.8. When my sub thumps, my volt gauge drops 1 tenth of a volt.
It's a very well built alternator. And the guy gets good money for it also. Just throwing it out there in case anyone was lookin for more power. Just make sure to increase the size of the charge wire. I went with 2 gauge.
Adios guys.
Old Oct 6, 2006 | 10:14 PM
shott8283's Avatar
shott8283
ive been wanting to put in a diesel alt 208 amp in my truck but like you said DD that you run a 8groove and i think we have 6 (or 7) groove pullys.. i figured if i get the one for the 5.9L 12V the mounting holes should be close to the same.. maybe some modification necessary.. and the nice thing is these style alts are considered 2 wire so they have internal rectifiers and the pcm regulates.
