springs
Old Oct 10, 2006 | 12:52 AM
zakimodo's Avatar
zakimodo
Default springs
Will 3/4 ton springs fit on a 1/2 ton truck
Old Oct 10, 2006 | 04:19 AM
silverram99's Avatar
silverram99
Default RE: springs
Not a 4x4 guy but as far as I know they will, I think the CTD 2500 springs will actually raise the front end on a 1500. If you are debating purchasing these springs you might wait for a definite answer. Welcome to the forum.
http://dodgeram.org/tech/specs/springs.htm
Old Oct 10, 2006 | 05:58 AM
mntnceguy's Avatar
mntnceguy
Default RE: springs
No, I don't believe so. 1/2 ton springs are 2.5" wide, and 3/4 ton springs are 3" wide. I guess you could modify your shackles and axle parches to get them in, but whats the point? Anyway, thats my .02
Old Oct 10, 2006 | 11:32 AM
don_ripley's Avatar
don_ripley
Default RE: springs
Yes CTD 2500 front coil springs will work on a 1500. The rear leafs don't swap though. The 3/4 springs should give about 1.5" of lift.
Old Oct 10, 2006 | 02:46 PM
steve05ram360's Avatar
steve05ram360
Default RE: springs
yes the fronts will, no the rears wont...
here is a chart for the fronts...I did this mod with springs out of the wrecking yard and got 2.5" of lift in the front.
Old Oct 10, 2006 | 11:40 PM
THEGOLDPRO's Avatar
THEGOLDPRO
Default RE: springs
yeah they fit and will raise it a good couple inches.
Old Oct 11, 2006 | 01:13 AM
zakimodo's Avatar
zakimodo
Default RE: springs
yaaa i have alittle sagging issue ans would like the lift of the 3/4 ton springs. so ill probably just get new 1/2 ton springs and forget the lift , thanks guys
