Need Help
Old Oct 10, 2006 | 07:04 PM
97Ram1500's Avatar
97Ram1500
Default Need Help
I have started to notice a skweek, so i replaced the idle pulley and tensioner pulley, the noise went away for about a day and is back again. I see no water leaking, so I don't know if it is the water pump or just another one of my pulleys is bad?
Old Oct 10, 2006 | 09:00 PM
steve05ram360's Avatar
steve05ram360
Default RE: Need Help
welcome to DF...
get a screwdriver or mechanics stethescope and put it on the water pump, alt & power steering pump to find out which one is the culprit. then you can swap it out as needed.
Old Oct 10, 2006 | 11:36 PM
quadro's Avatar
quadro
i was just wondering what the screwdriver will do. Is that another way find out what is making the noise?
Old Oct 11, 2006 | 03:05 AM
timwag2001's Avatar
timwag2001
hold the screwdriver to the waterpump and put your ear on the handle. It works like a doctors stehescope. You can hear all the internal noises of things.
Old Oct 11, 2006 | 12:12 PM
Socha_62's Avatar
Socha_62
Get some WD-40 or belt spray, took my squeel away instantly.
