Center Link
I went to get an alignment done this morning. They told me that I've got another couple of months with my center link before it goes out. It's got quite a bit of play right now. Is this a hard job? I like to do things myself, but I've never done a center link before. How much does one of these run?
I recently replaced all of the steering linkage along with the steering damper on my 01, except for the part of the linkage that attaches to the steering box. I spent about $450 at Advance Auto for the parts. I started working on the truck at 6:15 AM and had it completely back together by 8:30 AM.
Pretty easy job if you have ever done any tie rod end replacement work before. I would recommend before starting to spray all of the bolts that you will be loosening/removing with PB Blaster and let it sit overnight. When you start loosen all of the bolts before you separate any of the tie rod ends. It'll make you life a lot easier.
